The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
360 Vragen Bekijk alle
cycle lights blink washer will not run
washer will not run . no codes, cycle light will blink once when start is pushed
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
Ooit iets gerepareerd? Je bent een genie.
Deel je reparatie met #ImAGenius
We zijn allemaal genieën
5 Antwoorden
Gekozen oplossing
Unplug it for 5 minutes to allow it to reset then plug it back in and see if it gives you any codes.
Was dit antwoord nuttig?
Score 1
the door lock light didn't come on. when I unplugged the electric and plugged it back in the door light came on. it ran thru a couple minutes then shut off when the door light went out. can you help me? thank you.
fred
when i put a load in it starts and then stops and the light start blinking and i have to move the cloths around in the drum - or take some cloths out - but that only works sometimes.
Washer stopped with twelve minutes left on the timer clothes are dry enough to take out.the washer will not restart. I unpluged the machine for five minutes and when plugged back in no code appeared. When it was plugged back in a real low hum could be heard but still will not do anything
After turning power on I push the start button and hear a humming noise. Please help
Voeg je antwoord toe
michealwing zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 7
Altijd: 1,312
