Ga door naar hoofdinhoud
Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2170 Vragen Bekijk alle
After Screen replacement, some keys not working
Hi:
I just replaced the screen on my 4s and when I type just a few letters dont work. Everythng else seems to be working. Any thoughts?
Thanks
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Most likely a bad spot in the digitizer. If you turn the keyboard sideways you will probably find the same spots are dead on the phone and not just the keyboard.
Perhaps it is a poor quality part. Maybe you damaged or crimped the cable trying to install it. There are many possibilities. I would change out for a new glass and be sure to install it very gently and keep an eye on the cables attached to the screen. Make sure you dont bend them excessively and make sure they feed smoothly through the frame when putting the new screen on. This will help ensure you dont damage anything and the digitizer works correctly after install.
Hope this helps!
Was dit antwoord nuttig?
Voeg je antwoord toe
Bob zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 5,166
