Ga door naar hoofdinhoud
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Vragen Bekijk alle
iPhone 5 not charging or connecting to iTunes
So, i bought an iPhone 5 last week, the seller told me everything was working except the logic board. When i got it i did a soft reset and it booted up, it showed 10% battery. After the battery drained i tried to plug it to my computer and no response. Same with wall adapter. I replaced the dock connector and the battery and still no response. The phone boots up and functions perfectly but doesn't recognizes the lighting cable or any kind of power inlet. Any ideas what could be causing the problem? (I've heard something about the USB Power IC, but not sure about that). Thank you in advance!
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The logic board is the motherboard controlling the entire phone. Try Changing the lighting port and if that works, you are blessed.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Wisdom Banks, "replaced the dock connector" includes the lightning port
door
Thanks for your respond, it turned out it was the motherboard, I sold the iPhone and bought a new one. I did change the lightning and the battery with no luck.
door
Voeg je antwoord toe
Luis Fondeur zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 778
