Ga door naar hoofdinhoud
The fourth Google Nexus smartphone, released November 13, 2012.
75 Vragen Bekijk alle
What do I need to fix a cracked nexus 4 screen?
Hello,
i also dropped my nexus 4, it was a little drop but the screen has one scratch (not a big one) but the touch working in some places in the screen and not working in other places.
can anyone advise me which part should i change?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
You should change the whole screen assembly and you can learn how to replace it from this video http://www.youtube.com/watch?v=AZDAIgwbX...
Was dit antwoord nuttig?
Score 1
Hello!
The part that needs replacing is the display assembly.
You should be able to find one fairly cheaply but remember that you usually get what you pay for, so don't go for the lowest priced one, go for one in between. The ifixit shop does not stock the required part so try eBay :)
If you're not confident replacing it yourself then take it to a mobile phone repair shop if you are then proceed and reply with the results!
ifixit does not currently have a guide to do the repair, there may be one else where but I just thought I'd give you the heads up :)
1 Opmerking:
Where do I take nexus 4 cracked phone to fix it in Briarwood Mall Ann Arbor Michigan
door
Voeg je antwoord toe
ariana zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 13,947
