Ga door naar hoofdinhoud
Model A1051 / 4 of 6 GB harde schijf
87 Vragen Bekijk alle
iPod mini making clicking sound, won't boot up?
My iPod Mini comes on and shows an Apple symbol. After about 10 seconds or so, it gives the Apple web site address. Also, it displays a symbol of the drive with a line through it.
The iPod Mini is charged and battery is OK. When turned on it also makes a clicking sound similar to when a hard drive is failing.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Just get a Compact flash card and call it a day. You can't buy new MicroDrives, and a CF card would make this more stable and load faster in baby situations. Any reasonably large card (8GB+) will usually work, although you may need to do some research to be sure first.
Once the card is installed, you will need to restore the iPod in Disk Mode. To do this, hold the center button and the play/pause together until it's in Disk Mode. Restore it in iTunes when this is done.
Was dit antwoord nuttig?
Score 2
Thats your problem. The MicroDrive has failed. If you can get hold of one yourself, you could swap them out. If not, a repair company, such as www.dr-pod.com could repair it for you.
Mark
Score 1
Voeg je antwoord toe
Charles Scaglione zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 4,153
