Device does not boot after drop
Hi
have a macbook pro a1278 ... The device fell on the ground...now it does not boot anymore
When I plug the charger, the led ON the charger is always green.....
when I press the little button on the frame( to check the battery charging), the LEDS don't turn on....
any suggestions where the problem could be??
logicboard broken?
Update
how high is likelyhood, that the dc jack is broken due to the drop???(it did not fell on that corner)??
Is dit een goede vraag?
2 opmerkingen
Could be a few different things here. Where did it hit the ground on the edge/side or flat side down on the top/bottom? Do you have any dents and if you do where? Is the screen damaged in any way (cracked)?
door Dan
It hit the ground on the edge....(corner where the battery is)
I opened the device and removed the logicboard ... saw that one usb port is a bit damaged...the rest seems to be ok....[http://]
door mirko
