Ga door naar hoofdinhoud
A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
966 Vragen Bekijk alle
Toshiba Satellite U400-138 screen goes dark but still running, help?
So I did some research and no one else has this problem. I found a solution which is:
-I held down the start button for 60 seconds it worked but when i clicked on 'start windows normally' it went back to being dark.
-I also have no external monitor.
Help... please.
~Della
Is dit een goede vraag?
Score -1
1 Opmerking:
Does it work with the external monitor?
door
Voeg een opmerking toe
1 Antwoord
It could be just the connection that is loose, You could try to search on Youtube for your Laptop model and see if you have any luck, I did that for my Laptop screen that I broke and thanks to Youtube I was able to replace it fairly easily and cheaper of course. I actually have another Laptop that has the same problem you described but I have not bothered to repair it since I have an External Monitor hooked up to it.
Good Luck
Chris
Was dit antwoord nuttig?
Voeg je antwoord toe
Della zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 718
