Where exactly is the Flasher Relay for a 2003 Mazda Protege located?
Is dit een goede vraag?
Berry, the Turn signal/Flasher relay is under dash on drivers side. If you have a manual transmission is is almost directly above the clutch pedal. It is a gray colored box about 2 inches wide by 4 inches long. It is #5 in the attached diagram.
Hope this helps, good luck.
Was dit antwoord nuttig?
Thank You very much , it solved my problem.
Thanks
Ronald (Philippines}
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 39
Altijd: 11,105
1 Opmerking
Thanks oldturkey03! I will check this out immediately.
door Berry
