Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3272 Vragen Bekijk alle
How to Unblacklist My Device?
I purchased an Iphone 4 from gamestop and tried to get a quick prepaid service on it , and was denied because the phone was blacklisted. And being dumb I threw out the receipt smh ....Is there anything I can possibly do to unblacklist it ???
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Score 5
Een opmerking toevoegen
iPhone Batterij Fix Kits
Slechts $29.99
Buy Now
Slechts $29.99
Buy Now
5 Antwoorden
Gekozen oplossing
First check it here for black listing: http://www.imei.info/iPhoneBlacklistChec...
If it is indeed blacklisted, take the report to Gamestop (they should have a copy of your receipt) and demand your money back or a replacement iPhone. You did use a credit card to buy it, right? You can also report it to the police but if you are still in possession of it, you will probably have to give it to the police as stolen merchandise.
Was dit antwoord nuttig?
Score 2
You could contact your service center or the network provider.
Imei Track
try imeiesnrepair.wix.com/imeiesnrpair I repaired my iphone 4s ,not sure if they do 5 or 5s
Commentaar:
I used UnlockBoom service to unblacklist my iPhone. It worked fine for my verizon iPhone 4s.
door
yes I have the same problem
i have a iphone that i bought off a family member and it is blacklisted i need to be able to get a cheap fix on this please help
Voeg je antwoord toe
Matt T zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 2
Afgelopen 30 Dagen: 10
Altijd: 22,960
