Ga door naar hoofdinhoud
The iMac G5, powered by the PowerPC G5 processor, was originally released in August 2004.
453 Vragen Bekijk alle
Need pinout for iMac's iR sensor (iSight)
RE: iMac G5 (iSight)
IR part: 820-1884-A
Need pinouts for J1 and J2 (I presume alternate solder points).
As best I can tell, the iR sensor from the iMac is USB. A while back (before I had one with a built in camera or iR, I saw a USB pinout.)
Anyway, I now have a dead iMac with iSight and iR sensor. I'm looking for the iR sensors pinout so I can convert it to a standard USB cable and jam it into a PowerMac G5 tower (which never had an iR sensor.)
Any help would be appreciated.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Not sure if this is what you want or not but here is one persons answer. Good luck Ralph
http://www.applefritter.com/node/23056
Was dit antwoord nuttig?
Score 3
3 opmerkingen:
Answer near the bottom of the page. Ralph
door
+ research
door
Do you think this board is still supported in modern (10.8+) OSes? Should I buy this, or the more expensive MacBook Pro IR board?
door
Voeg je antwoord toe
ct2193 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 2,895
