Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatie-informatie en probleemoplossing voor zitmaaiers van het merk Craftsman.
Repair Manual for Craftsman Riding Mower
How can I obtain a repair manual for a Craftsman Riding Mower?
Is dit een goede vraag?
Score 51
26 opmerkingen
Depends on what model your mower is:-)
door Deel
The model number is 917.2736403
Why would not all the Craftsman riding mowers have repair manuals available?
door Deel
I am sure they all do, but some off those need to be purchased through Craftsman and/or the dealers while others are downloadable.
door Deel
why would oil be coming from the exhaust
door Deel
why would oil be coming from the exhaust on my LT 1500
door Deel
21 commentaren meer tonen
Voeg een opmerking toe
3 Antwoorden
Filteren op:
Gekozen oplossing
Leon, download the manual from here. It has the user manual as well as the tractor repair manual in the back. If you are looking for something more specific, let us know. Any engine repair etc, will require the service manual from the engine manufacturer, i.e. B&S etc. Hope this helps, good luck.
Update (05/29/2022)
Difficult to keep manuals online for 9 years. It is now posted on the bottom of this page Craftsman Riding Mower as "Craftsman_917_2736403_DYT 4000"
Was dit antwoord nuttig?
Score 18
22 opmerkingen:
Need a manul for a Craftsman LT1750 Limited Edition riding mower with Koehler 17 1/2 power engine
door Deel
Manuals Lib.com
door Deel
log onto / Manuals Lib.com
door Deel
need service & repair manual for craftsman tractor 917.258691
door Deel
Need a deck for 917.272011
door Deel
17 commentaren meer tonen
I have a t140 craftsman riding mower.I took off the drive belt pulley assemble. I can not find how to put back on tractor. When I put together the belt will not disengaged with the motor running. I cannot the find adjustment on this t140 tractor. This only has two (2) pulleys NOT (3) pulleys.
This unit has left pedal which disengage the belt and brake. The right pedal only drive the unit. The more you push the pedal down the faster it will travel.
1 Opmerking:
A shop manual will help a lot.
door Deel
MTD makes many rebadged tractors including Craftsman. Search for craftsman tractor manual or MTD tractor manual and find one the looks similar. Most drive belt arrangements will be the same. My Troybilt has and idler pulley that tightens/loosens the belt. There are 4 pulleys, one on each blade drive, one on the motor and the idler. I can't picture how a 2 pulley system would work.
If you can't find a manual, you might also search parts stores for part diagrams.
Voeg je antwoord toe
Leon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 33
Afgelopen 30 dagen: 99
Altijd: 61,874
