Ga door naar hoofdinhoud
The Droid Razr is an Android-based, 4G LTE-capable smartphone designed by Motorola.
60 Vragen Bekijk alle
Overvoltage at 12V and Died Razr
Heedlessly I connected a car charger wrong and my razr took a power surge at 12v. Now the phone will not turn on and will not charge, it seems dead. What can I do to solve this problem?
Is dit een goede vraag?
Score -1
2 opmerkingen
You will have to open it up and check for some obvious damage. Look for some burned, charred or missing components first.
door
I have just opened it, I compared it with another razr XT910 and seems thar are identical.
I exchanged the motherboard and I have found that it is the cause of damage.
Unfortunately, the chip on the motherboard are covered with metal parts, but I don't know how to remove for exploring the damage circuit.
Meanwhile, thank you so much for the help you're giving me.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I would check for an onboard fuse. use a magnifying glass and look around the charger area for a F1, F0, etc.. Can you post clear pics of the mainboard? Both Sides
Was dit antwoord nuttig?
Voeg je antwoord toe
Maurizio Luciani zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 295
