Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
153 Vragen Bekijk alle
Screen comes on but does not light up.
I have a PowerBook G4 Aluminum 17" 1-1.67 GHz and it was working fine. All of the sudden the screen comes on but does not light up. I was told that it was probably an inverter board, so I bought a replacement. After a 6 hour tear down and reconstruction it does the same thing. All wires are connected and tight. Any help or ideas would be appreciated.
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
Ooit iets gerepareerd? Je bent een genie.
Deel je reparatie met #ImAGenius
We zijn allemaal genieën
1 Antwoord
Gekozen oplossing
It's a widespread myth that the inverter is the problem in these situations (spread mostly by people who have never done a laptop repair), and 99% of the time it's actually the inverter cable, or the screen itself. With MacBooks and PowerBooks it typically ends up being the screen, however you might want to replace the inverter cable first, since it's a relatively cheap part and there is a chance it's the culprit.
Also, before you start spending money on parts, you'll want to connect the laptop to an external display. If that works fine, you'll have ruled out the logic board as part of the problem, whereas if the external display doesn't work, it's possible you've got a video chip issue.
Was dit antwoord nuttig?
Score 2
Commentaar:
Agreed +
door
Voeg je antwoord toe
mrclark zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 707
