Ga door naar hoofdinhoud
Model A1213 / 8, 16, or 32 GB capacity
216 Vragen Bekijk alle
Turns on & off every 8 seconds
After a full charge. I am able to use the unit. Then when finished I turn it off but it then starts to power back up with the "apple logo" and then shuts off....eight seconds later powers back up with "apple logo" and continues this process until the battery power is drained.
I have run trouble shooting programs from Apple website, but this does not correct the problem.
Apple suggested I take it to a repair shop.
Anybody have an answer to this?
Steven C.
Is dit een goede vraag?
Score 2
1 Opmerking
Thank you for your ideas.
I will relay this to my son and see if this solves his iPod problem.
Mark
door
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
Stuck Power Switch?
I wonder if the power switch is stuck or otherwise bad and needs replacing. By this I mean the parts inside the unit, not necessarily the exterior portion of the switch. --Bob
Was dit antwoord nuttig?
Score 3
3 opmerkingen:
Hi, how did you format the title like that?
door
Under "Add Your Answer", click the icon which is to the left of the "B" (Bold text) icon. I like using headings to convey the gist of my reply.
door
Had the same problem with my iPod Touch 8Gb 1st Gen. I tested the ON/OFF switch and found a resistance even if you did not operate the button. Hardest thing was opening the case, this took about 1 hour, the Switch took about 5mins to change. It is now working perfect. Smithtick
Score 1
You could try formatting it so it was like new, but then you'd lose all your data.
'Same Problem...But Power Switch is OK.'
My touch 1st gen suffers from the same affliction, but the power switch is not the culprit. My touch continues the failure mode even when the back is off, ie power switch is out of the loop.
I have restored the OS to no avail, so I doubt it is a software issue.
Any ideas? -, John B.
Voeg je antwoord toe
birdsfishing zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 3,361
