Ga door naar hoofdinhoud
Model A1046 or A1095 / 1280x854 screen resolution
164 Vragen Bekijk alle
PowerBook Al 1GHz - 4 Beeps at Startup
received today a AL Book
seller said that it beeps 3 times, but unfortunately - it beeps 4 times (light flashes 5 times) - so the boot rom should be faulty
is there any way to fix this problem?
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
2 Antwoorden
Gekozen oplossing
The boot rom is not on the hard drive but in a flash memory module on the logic board (just like the integrated memory modules). The boot rom is an instruction set that the computer use before loading the OS. I think the boot rom can only be modified by a firmware update.
Was dit antwoord nuttig?
Score 2
Commentaar:
thanks for the reply the problem would be, that there is no firmware update listed (or i'm to blind to find it)
was there a ASD for the 1ghz or was the ASD starting at the 1,33 (but then would the ver. # 2.5.7 would not make much sense) - a simple yes or no answer to this particular question would be enough
door
If the boot room module itself is faulty I think that means a logic board replacement. If the boot rom image is corrupted maybe it can be reflashed but I really don't know (Google search..). Also the boot rom module might be physically replaced by a working one (salvaged from a dead board) again I don't know if it can be done....Sorry
door
ok thanks,
i will try something with the ASD, also found some firmware images - but first i will read a little bit more about that - in the morning, it's almost 12:38 am - bedtime ;-)
door
to "close" this question: i sold the powerbook - the buyer has a good logicboard for the beautiful case (no scratches or something else) - well, some things can not easily fixed - the only way would have been an otherwise toasted board, swapping the chips would have been the easiest way to fix it
door
Here's Apple explanation of the different startup beeps: http://support.apple.com/kb/HT1547
Score 1
Commentaar:
Good info + Ralph
door
right, but can the 4 beep problem be fixed ?
door
First thing I would do is zero out the hard drive to eliminate boot block problems
door
I replaced the hdd - same beeping
there is nothing on the screen, wont boot from the setup disk (optical drive is ok, took one of my spare drives)
door
What's your status on ASD issues? I have the 3S123 with updates 2005.06.07 & 08. Have anything to trade? Contact at mayer@door.net
door
Voeg je antwoord toe
markus weiher zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 2
Altijd: 3,737
