Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Vragen Bekijk alle
Digitizer problem, one area not working
Hi, I have an Iphone 4S that has one certain area of the screen sometimes not responding to touch, the area is "4,5,6" on the keypad when trying to dial a number.
Does anyone have any solve around this?
Thanks,
Mykel
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Yes. You have a broken digitizer, so replace the display assembly.
iPhone 4S Screen
iPhone 4S Screen Afbeelding
Product
iPhone 4S Screen
$34.99
Was dit antwoord nuttig?
Score 1
1 Opmerking:
i have repaired over 100 phones, just ran into a problem where a strip of the digitizer is not working. the problem occurs from Q to P on the keyboard in portrait mode. i have an iphone 4 assembeld with no screen and i use it to test screens. the screens i am using work fine with the test phone. upon inspection of the 4/s i see no problem areas. any suggestions? also i tried to hard reset/ and hard restore the phone with no success after updating.
door
Het nuttigste antwoord
I had a similar problem with a 3gs. I tried a couple of spare screens but could not get rid of the dead spot. A narrow vertical area corresponding with the letter I when the keyboard is on screen. I put the main board under my microscope and found small traces of what looked like solder splashes on two of the pins in the digitizer socket.
Score 1
i put a new digitezer on the phone and still some of the letters don't work in portrait mode , turn the phone in landscape all the keys work ...
Voeg je antwoord toe
mykel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 2,310
