keys on the keyboard stop working
Hello some of the keys on my keyboard stop sounding. Does it means i´ve got a broken key? I am sure the keyboard hasn´t been hitted by no means.
Is dit een goede vraag?
Hi Mario,
You can use the guide for troubleshooting the YPG-225 provided by ifixit here. There is a section labeled "Keys don't produce sound". If you need the manual for this keyboard, it is here.
If those keys which do not produce a sound are somehow hanging (are lower than the other keys) and are somehow slack, the problem is related to broken keys. They need to be replaced. In this case, you can use this guide here on ifixit.
Just keep us posted what you figure out.
Steffen
Was dit antwoord nuttig?
I love this website and the help provided by people like you. Thank you!
Hi. Thank you. Where can I buy replacement keys for my keyboard (Yamaha DGX 220, same as YPG 225 I think)? Will DGX 230 replacement keys work? My problem is that a Db key is a bit loose amd wiggly. It will often play louder than its supposed to.
This tutorial is of my exact keyboard. Is there a tutorial for when fixing all of one key across the entire keyboard? E’s in every octave have stopped working. Every other key works great.
The problem isn't usually the board.. its the rubber contact that either need replacing or cleaning. Clean with pure alcohol.. I use Isopropyl alcohol and a lint free pad like chamois. Don't use cotton bids.
If the fault is on the first octave the part number for the contact is V3413800
Top Octave? V3413700
All the other octaves: V4313600
If it is the board its in two halves... lower half. Pt number is V3414200 and the top half is V3414300
Contact Yamaha in your country and ask for spares dept, In UK the number is 01908366700 You can pay by card.
cheers
Iain (the engineer)
Keyboard Repair Centre, Birkenhead. UK
How do you clean the rubber contact?
Clean with alcohol and lint free cloth see my post above.
My PSR970 speakers sounds like there water when I play it but there isn’t. What’s the problem?
"A" Key is not working in all octave in my Yamaha psr-410
Hi, I have a Yamaha psr-e223 and after removing the rubber contacts and cleaning/undusted the board, the B2 flat note keeps "ghostly" triggering itself, I turn it off and on but after a while it triggers itself again, first randomly beating but then soon gets stuck pressed on,
disassemble everything again and double checked, but the note keeps triggering itself with not external/mechanical touch to the board. where is the problem? Can't find any help on line about this.
My yamaha dgx 230 had the same problem too, except, if I pressed it lightly, it sounded as if I were pounding on it. And the bad thing is, it happened to 14 notes, which were the same G#'s and the same D's. But if I press on it normally, it doesn't make a sound. Do u think it has something to do with dust or the rubber pads?
If it's all the same notes it's more likely to be the connections from the board to the main board. Or a crack in the track from the pad to the connector on the contact board
I have the same exact problem. All D keys and G# keys stopped working
I have the same problem.. when i press g or d keys both g & g# plays
I had a problem exactly like this on my yamaha psr 463.. I contact the service center but they're close due to lockdown... But i didn't want to open it myself as it still have warranty so i decided to blow below the keys with a hair dryer for 2 minutes and and guess what, it worked.... I'm reading all these post and decided to try that and I'm posting this as soon as that happened. Hope that helps
I just had the exact same problem, D and G#s weren't working. I followed the procedure with a hair dryer just as said in the previous comment, and it worked!!! :D :D Thank you @sawmajr
I'm a Yamaha engineer at Keyboard Repair Centre in Wirral.
I have had this fault in the past. It may be the volume control which has gone high in value. If you need the part number then let's know. Its not a difficult job but you need desoldering and soldering skills.
Oke, that's great!. I would like to purchase that part then.
Can you indicate what to do next
Regards
Hugh
Hi, I have a Yamaha psr-e223 and after removing the rubber contacts and cleaning/undusted the card, the B2 flat note keeps "ghostly" triggering itself, I turn it off and on but after a while it triggers itself again, first randomly beating but then soon gets stuck pressed on,
Can you use spirit to clean the rubber contact or the circuit board....I also use Yamaha psr e423 and some keys seized to sound and I realized the problem is from either the rubber or the circuit board.. I need help please.
Anything that does not leave a residue. All ohol is best... try vodka
I tried disassembling & cleaning, and more keys "died". I found that if I hit the keys over and over and over, it seems to come back to life.
This site seems to offer some replacement parts:
I have yamaha psr i455, from yesterday its D# and A key of every octive was not working. I am trying many ideas which givesn on internet. I have a hair dryer i use on my keyboard and now my keyboard is working properly. I think its lhappend because of moisture due to rain… i purchased Silica Gel packet and kept near to keyboard then after no such problem happened.
If it is all the same note that fails, then there are 2 possible reasons for this. 1) there is a break in the copper track on the pcb or 2), a bad connection on the edge connector. If 1) then it is not an easy fix. If 2) then it could cured by resoldering it.
I just had this problem where my E and Bb keys had stopped working entirely.
I used a firm slap directly to the right of the logo above the keys to jostle things back into place.
Works so far, will update if anything changes.
-Roon
Hi, on my Yamaha e223 Bb2 note triggers itself even without the rubber contact on it. The board is clean and yet it starts sounding by itself, only when reassembling rubber contacts and keys and pressing the E note on same octave the sound stops, as if pressing E interrupts the signal of Bb to the board, but as yet another issue, E doesn't play at all ever since...was that the same issue of yours?
Yamaha psr e 343 keybord d&g# key all octiv not working
Same thing here. I just got a brand new PSR 373 and after just 1 month the D and G# keys of all octaves stopped working. I sent it to the repair shop and I am waiting their evaluation to see what happened
I have a yamaha clavinova clp 920 I'm trying to rescue. I ha e tried and tried but the right half of the keyboard won't make sound unless I press it very hard but the note will note sustain its just a quick little note. Iv tried Cleaning the keyboard contacts but it does nothing. I wanted this to work so badly. Does anyone know how I can get the right half of the keyboard to play notes again?
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 31
Afgelopen 30 dagen: 117
Altijd: 71,564
31 opmerkingen
Hello, my yamaha keyboard stops playing after about 10 minutes. To start it again I need to hit the middle leg of the transistor with one of the wire. What could be the problem?
door oluka
Replace the transistor or resolder it to the board
door iainogilvie
my keyboard has the same problem with some of the keys not sounding but i have a Roland D-20 Multi Timbral Linear synthesizer Multi Track Sequencer are the same thing happening to to my keys
door carriehatfield6
My keybord has aproblem when i press one key it sounds two notes extra both one note up and the other one lower at the same time
door Geoffrey
Hi ser, my yamaha keyboard has aproblim, when I turn on thers com's up unexpected error what are whe doing them
door Crisanto Tucaling
26 commentaren meer tonen
