Ga door naar hoofdinhoud
The HP LaserJet CM1415fnw is a multifunction color printer produced by Hewlett Packard.
19 Vragen Bekijk alle
ADF Won't pick up paper
The ADF(automatic document feeder) will not pick up paper, either a single sheet or multiple sheets. HP and my extended warranty says it can't be fixed, printer is only a bit over one year old. Anyone know if a ADF unit is available?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Maybe I will dismount the complete unit to replace this (cheap?) cable up to ADF unit. Could be the problem as my ADF does nothing than saying - no document.
Anyone having a tech repair guide for me?
Was dit antwoord nuttig?
Score 1
Inkjet printers are cheap enough that if they break, buy a new one and recycle the old one. Other types of printers can and should be fixed.
2 opmerkingen:
It doesn't seem broken to me; more like a gear cog out of sync due to clearing paper jam. Would appreciate guidance how to realign.
door
The paper get crashed after that the printer stop printing as if it did not receive the order to print
door
The paper get crashed and after removing the torn paper the printer stops printing, as if it did not receive the order to print
just now by fmankarious
Voeg je antwoord toe
Roger zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 3,180
