Power supply disassembly question - iMac intel late 2006
Can I skip some steps in disassembly my iMac 5.1 like (speakers, logic board...) to reach Power supply? I'm not changing it, only replacing a faulty capacitor
TNX
Is dit een goede vraag?
TNX
Hi,
I don't see why you can't skip these steps. After removing the TFT panel you should have easy access to the power PCB. I exchanged a HDD on a similar unit, and did not need to remove the logic board or speakers.
Was dit antwoord nuttig?
Only problem is disconnecting the power cable, because the heat sink is on he way, but i can always unsolder it from power supply unit. At firs it looks so scary, but after iI was thinking a little , it's very easy disassembly
Studying the step by step guides, I now see what you mean. When removing the HDD you can't gain access to the AC connector from the side ?
Unsoldering the AC wires is an option too, but I would prefer to remove the logic board. It can't be that hard and it keeps you in shape !.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 5,114
