The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
597 Vragen Bekijk alle
No service after lcd digitizer replacement!? (Tmobile)
Have fixed over 20 GS3s in my day, and this of course is my own personal one. After the screen was replaced, I only get service in WIFI areas. One/Zero bars everywhere else. Replaced sim card and even antennae. Still happening. I noticed a bit of water damage and scrubbed it. STILL didn't help. Any advice please? Maybe software? Or a chip may have broken off? Thanks in advance.
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
Ooit iets gerepareerd? Je bent een genie.
Deel je reparatie met #ImAGenius
We zijn allemaal genieën
4 Antwoorden
Gekozen oplossing
Turns out the back housing had accidentally been swapped with a verizon, which seemingly fit, but later would knock the antennae off as well as not matching with some of the important grounds. Thanks
Was dit antwoord nuttig?
Score 1
Sir can you help me? I have the same problem but I don't know how to fix it. How did you fix your problem?
Hi Julia when you open it up there is a long cable running up the right hand side make sure it's connected proporly
Commentaar:
but is it the wifi antenna your are reffering to?
door
@con arent you referring to the wifi antena?
what antena or part should i look for the network issue?
Voeg je antwoord toe
Austin Harris zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 1,727
