Ga door naar hoofdinhoud
2, 2.26, 2.53, or 2.66 GHz Core 2 Duo processor
106 Vragen Bekijk alle
Raptor HD replacement for Mac Mini Server?
Is it possible to replace the original hard drives in a mac Mini Server with a western Digital Raptor HD? Will the power supply spin it?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
The mac mini uses a 2.5'' harddrive. I don't know of any WD Raptor drives in the 2.5" form factor. The other concern here is heat and power usage. WD Raptor 10K drives are also major power hogs, so the machine will probably shut down from overdraw.
In short, it won't work. Get a SSD or a 7200RPM drive.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Agreed +
door
It is possible, but raptors are quite noisy and get hot, the latter makes them especially not good for mac minis. I would go with ssd or green, or blue models
1 Opmerking:
The Raptor is a 3.5" drive (has a special heat sink), sorry just won't fit as it was designed for 3.5" HD frame.
door
Voeg je antwoord toe
Phillip Lauer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 5,855
