Ga door naar hoofdinhoud
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Vragen Bekijk alle
Why won't my iPod turn back on?
I just finished replacing the battery in my ipod touch 4G and it won't turn on. I've noticed that the board above the battery, below the front camera is slightly warm. No cables are ripped/broken. Anyone have an idea what could be wrong ? I also followed the ifixit guide on how to replace the battery to the word...
Is dit een goede vraag?
Score -1
5 opmerkingen
What was the original reason that you replaced the battery?
door
I replaced it because the battery life was very poor.
door
Will it not turn on if you plug it into the wall?
door
Nope. Wall or computer, it won't turn on.
door
The board is now cold. instead of warm.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Here's a tutorial with pics that everyone has been requesting. I've used this method over a dozen times successfully. Good Luck!!
There are 3 small battery terminals (shown below). You only want to touch the one to the far right (circled below). Avoid touching the other 2 terminals!!
see the pics
http://guide-images.ifixit.net/igi/YiaQu...
http://guide-images.ifixit.net/igi/AnevP...
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
thing you should always do b4 a screen replacement is make sure itunes detects it!
door
Thanks you sooo much!
This worked! ! ! ! My ipod is working again !
Only downside is that there's a small white line going across the bottom of my screen(Most likely has nothing to do with the battery ) buy HEY I'm not complaining ! :-)
Thanks again !
door
thats fantasic the white line im sure is a fault in the screen
door
Voeg je antwoord toe
Creativemagic zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 242
