Ga door naar hoofdinhoud
Model A1001 or A1025 / 667, 800, 867, or 1.0 GHz G4 processor
50 Vragen Bekijk alle
Vraag afgerond
My PowerBook G4 doesn't recognize my external hardrive
Is dit een goede vraag?
1 Opmerking
How long has this been happening--what OS are you using--has it ever recognized the hard drive? Ralph
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Change the port you are plugged into. Go to Applications - Utilities - Disk Utility and see if that program will see it, if so try to repair it. Check your external enclosure to see if it is powering up. I would also change the cable to the enclosure.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
+1 Ralph
door
Ralph,
Thanks for your answer. I tried it but it did not work.
marcela
door
All the Titanium models have poor and easy to blow firewire port. I would be not surprised if yours was dead. Try a known working firewire device in the port to troubleshoot it.
Now if you talk about a USB external drive, maybe you need to connect the drive in the two USB ports to give it enough power to mount on the desktop.
Score 2
1 Opmerking:
Thanks, for your help I bought a USB 2.0 Mini-B Male to 2 USB A Male Y-Cable and it worked. Thanks a million.
door
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,422
