Ga door naar hoofdinhoud
Hoe je je werktuigen repareert, zodat je ze kan gebruiken om andere reparaties uit te voeren.
2228 Vragen Bekijk alle
Vraag afgerond
I've had to deal with recessed screws while disassembling a laptop
I am going to purchase either the Home tech Toolkit or Pro Tech Toolkit (depending on finances) soon.
I also need a small assortment of philips-head screwdrivers that can hold a screw upright while putting it into a recessed place -- way too deep to hold on with my fingers. Enough room for the screw to fall over, but not enough room to put tweezers in with the screwdriver.
It doesn't look like either toolkit has these, and I can't imagine that you don't sell them. Please point me to the right product.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi Maggie, thanks for your question! The bit kits included in the [gekoppeld product ontbreekt of is uitgeschakeld: IF145-047] and [gekoppeld product ontbreekt of is uitgeschakeld: IF145-072] each contain a 60 mm driver extension that may allow you to reach into recessed screw holes.
However, in some cases this isn't thin enough—for those situations you'll need a fixed driver. We sell these for every Phillips size, that can be magnetized to hold onto screws. For laptops I'd recommend a Phillips #1 and Phillips #0. For really small recessed screws, you'll need a Phillips #00.
Phillips #0 Screwdriver Afbeelding
Product
$5.49
Phillips #00 Screwdriver Afbeelding
Product
$5.49
Phillips #1 Screwdriver Afbeelding
Product
$5.49
Was dit antwoord nuttig?
Score 1
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,225
