Ga door naar hoofdinhoud
The Mac mini family was first introduced in January of 2005.
1251 Vragen Bekijk alle
Mac Mini not booting right away
Hello, Yesterday I tried to install windows with bootcamp on my mac mini, and when I tried to install it, it said that it could not be installed because the partition was not in the NTFS format. It said format but I did not know if it would format just that partition or the entire hard drive so I just completely exited out of the windows installation. When I tried to boot in to OSX 10.8.3 Mountain Lion after this, it would not boot right away. I searched the internet on my other computer and it said to hold down the alt/option key to get the partitions up on the hard drive to choose what partition to boot from. This worked and I was able to get into OSX. Is their a way that I can fix this so that it boots into OSX right away instead of holding down the alt/option key?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Use Disk utility to delete any other partitions that you are not using, forcing your mini to boot from the only available partition.
Was dit antwoord nuttig?
Voeg je antwoord toe
Josh K zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 163
