The Kenmore Elite HE3 is a washing machine by Kenmore.
620 Vragen Bekijk alle
Washer drains spin cycle, but won't spin.
Washer drains, but won't spin during the spin cycle. I can't manually turn the drum either. It is stuck.
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Score 4
Commentaar:
I have a kenmore 500 it will drain agitate but will not spin clutch is tight looks good and the coupler looks good can the lid switch be the problem ? Like I said it will drain and agitate but will not spin
door
My kenmore elite washer will not spin, agitate works what is the problem?
door
My kenmore elite washer will not spin, agitate works what is the problem? All other cycles seem to work fine
door
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
3 Antwoorden
Gekozen oplossing
Motor Coupling
If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt
If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Lid Switch Assembly
If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Drive Motor
If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly
If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly
If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Was dit antwoord nuttig?
Score 5
Commentaar:
It is a Kenmore Elite HE 3t and was making alot of noise for a few weeks, but last night it stopped spinning during the spin cycle. I tried to turn the wash tub and it is stuck; so I can't manually spin it. I was told by a repairman over the phone that it was either the spider arm had broken or the bearings (sp?).
door
@mayer Thanks for listing possibilities it has helped me out in my troubles of narrowing down my troubles
door
what i need is the plastic plug in from the wiring harness above --someone cut it off and by passed the lid switch ---but will still need help
door
Ken - For a better explanation, start a new question and give your make a model number. Maybe I can find you correct part.
door
I am so upset with my washing machine I am thinking a stick of dynamite would fix it just fine!!!
door
I have a samsung he washer. It will not spin.
It drains the water but no spinning. What
could the problem be? thnx
My washer agitates fine and if I turn the timer knob back to where it should sping it spins and also spray in the water as it would normally
Voeg je antwoord toe
Shannon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 102
Afgelopen 7 Dagen: 470
Afgelopen 30 Dagen: 2,760
Altijd: 62,965
