Ga door naar hoofdinhoud
Hard Drive & RAM upgrade
I plan to upgrade my iMAC G5 1.8GHz 17-inch. My questions are: if the computer can only be increased to 2 GB RAM (1 GB now), how large can the hard drive be increased to (80GB now)? What is the max size hard drive this model can handle? If I enlarge the hard drive can I increase the RAM greater than 2 GB safely? If so how large? Basically what is the max I can go with this computer? Any other recommendations?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
RAM and HD are like car Engines and Fuel Tanks... putting more gas in the take wont change the horsepower, increasing the horsepower doesn't change the size of the gas tank.
Your machine can run a max of 2GB RAM 2x1GB chips (that's limited by what the CPU can manage).
Your max HD is limited by space, heatand backward compatibility issues (realistically up to 500 or 750GB should be plenty of space). Your 9 yr old machine uses SATA I (1.5Gb/s) transfer speed... many of todays SATA III drives claim to work with SATA I - but there have been complaints about those that don't play well, hanging and freezing. Whatever drive you buy ensure that the vendor guarantees it will work and will swap/replace the drive if it doesn't.''
If this Answer is helpful please remember to return and mark it Accepted.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
jacob zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 476
