My iPhone says "charging is not supported with this accessory." Why?
I tried to connect my iPhone to my computer. Tried charging it through my wall outlet, my radio, the cable, and every iPhone charger i have. Plus I had my iPhone put to unlock, so i don't want to lock it again. Help me :( What do I do???
Is dit een goede vraag?
6 opmerkingen
The first thing you want to make sure off, is that you have a proper cable. I've had an aftermarket cable that gave me the same error. If your cable is a proper one, replace the dock connector.
door oldturkey03
Priscilla Martinez, that usually has to do with a signal from the dock connector. If you have a cable or a device that is not properly identify through your dock connector, it will give you that particular error message. Of course if you have a good cable, it is the dock connector that is at fault. The other way to test it, is by using a docking station that worked before, and see if it still works.
door oldturkey03
try cleaning inside the dock port..you often get this message if there is debris on the pins.
door pollytintop
yep my had a big ol' piece on the pins - thanks - alcohol to the rescue
door Sandra Griffith
I have an iPhone 4 and when I use my charging cords or the speakers made specially for iphones a lot of times it will say it may not be supported but it will work to play music but I will not charge .....any ideas????
door Ashley Kravatz
1 commentaar meer tonen
