Ga door naar hoofdinhoud
Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Vragen Bekijk alle
Vraag afgerond
battery doesn't last after pop spill
long story short, my Mac got a ill Pepsi spilled on it a month ago. when it happened, the ac adapter light would be dim when you plugged it into the Mac but the Mac was dead. it made a small fan sound when you pressed the power button but nothing. it would come on only after you opened it up and unplugged the battery and plugged it back in. I did that a few times after the spill. it has seemed to have gotten over that but now the battery can't seem to last a day without dying and gives you the beeping on boot up when you plug it in and power it on. I did the best I could to get the pop out after the spill, it didn't get much inside that I could tell. I don't know if the battery is shot or something else. it runs fine as long as it gets charged more than it use to be. what could be wrong? I need my Mac and can't afford a new one. thanks all.
Is dit een goede vraag?
2 opmerkingen
What kind of beeping does it give you?
door
it boots up, on the apple screen, the loading bar fills up, then it stops and gives you 3 beeps, pauses, then 3 beeps. it does it when it is completely out of power and you have to plug it in in order for it to turn on. does this help any?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The three beeps indicate a RAM error. Try reseating your RAM.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
it only does that when it runs completely dead and u boot up while charging, I've been told that the needs to be reseated so ill try that, would that any affect on the battery prob?
door
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 174
