My laptop is charging, but it won't come on.
Two days ago, a bottle of coke spilled inside my backpack and got into my laptop. At first, it wouldn't charge or do anything. I put it in rice for a few days, and now it is showing that the battery is charging (the green light on the plug is shining). Does this mean anything good/bad like that the motherboard works, the battery is fine, etc...?
Is dit een goede vraag?
1 Opmerking
not being a Mac person, the only advise I can give you right now, is to not try any further to start your MBA. This could cause further damage. Remove the battery and all power components. Remove as many components as possible using the Step-by-step guides. Clean every thing very carefully with 90%+ isopropyl alcohol. Do not forget the connectors and cables ends. If you do not clean it properly, you are running risks of having corrosion damage to your motherboard. Once you have it cleaned, reassemble and re-evaluate for specific errors. Check this post as well Liquid damage, battery charging as normal but won't switch on..
door oldturkey03
