Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Vragen Bekijk alle
Vraag afgerond
How to build your own using parts from 3g
Hello,
I have an old Iphone 3G that is still fully functional. However, I intend to switch to a 3GS by building one for myself.
As the two models are very much alike, I was wondering what components from the 3G can be used to build the 3GS.
I already know that the display and motherboard don't work:) So how about the others?
Also, is there any workaround for the display to work on the 3GS? As far as I see it's only a connector problem.
Thank you in advance for your answers.
Serban
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
Different parts are:
1) LCD
2) Digitizer
3) Antenna
4) Battery (Could work but not safe)
Was dit antwoord nuttig?
Score -1
1 Opmerking:
Thank you. So this project seems useles, as I'd have to replace almost everything...
door
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 172
