Ga door naar hoofdinhoud
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
368 Vragen Bekijk alle
logic board / display connector L9000 coil charred
The small SMD coil (L9000) under the display connector on the logic board is charred.
The display connector was damaged previously (broken shield) and every time I was transporting the iMac I had to either smack it or open it and wiggle the display cable in order to make it work.
This time it might short-circuited one of those pins to the ground (the twisted wobbly shield) and hopefully only that inductance died.
Here is a picture from the crime scene: http://cl.ly/image/222v2L222z1M
I wonder if there are any options to repair it.
Is dit een goede vraag?
Score 2
5 opmerkingen
What are the last three digits of your serial number? What numbers are on your motherboard? What processor is it?
door
Serial: CK0330CRGXU EMC 2390
iMac 27" Intel i7
Where should I find the numbers on the motherboard, I took off the screen but I don't see anything on the PCB that would look like a serial or type, do I have to remove the logic board completely (to see the CPU side)?
door
that should be enough information to find out what you want to know :-)
door
Did you get in hold of the right inductor? If so, where did you get it?
Thanks!
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Laurian, looks like your L9000 is a 250OHM inductor used as a filter. The connector is a 20389-Y30E-01. The inductor will be easier to find than the connector. The difficulty in finding it, is because it is a 32 pin and will need a bit of searching. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 4
4 opmerkingen:
Lovely, so, I'll need a SMD choke, 250 ohms, any idea what inductance in nH should I look for?
door
Hi Laurian did you figure out what part you needed? All the SMD inductor's I find have values in nH or uH.... If you could send a link that would help.... I think I've nailed the package size which is 603. Any help would be greatly appreciated.
door
I would like to know also. Have a couple iMac with same problem
door
same Problem
door
Voeg je antwoord toe
Laurian zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 1,606
