Why does my wifi show 'No Hardware Installed' after replacing it?
After buying a new wifi chip and doing a clean install of mountain lion, the wifi still shows no hardware installed ? what can i do ?
Is dit een goede vraag?
1) try to reset PRAM and NVRAM http://support.apple.com/kb/HT1379
2) check all connection
3) here same question
Wi-Fi "No Hardware Installed" even after replacing wi-fi card
Was dit antwoord nuttig?
tried resetting PRAM and NVRAM. checked all connections. also on the other thread there was no fix. should i try buying a new cable ?
ehh yes! there is cable issue or in logic board connector..
ive read on some forums that if its a logic board connector problem, then the webcam wouldn't work. however my camera works for me. could it be a software problem?
you have to try it on other friends mac if you can...best way for no less money and time.
good luck!
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 683
