Ga door naar hoofdinhoud
The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
201 Vragen Bekijk alle
How to repair a mini micro usb port connector
looked all through your guides didnt find any information trying to find how to remove my usb port connector thats in my phone to replace it with another one just trying to figure out how to do that please let me know i have a samsung galaxy s2 model SGH-T989
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
mike, you could either change the Charging Port Dock Connector Flex Cable or try to solder a new micro USB port on your flex cable. The flex cable would be available at places like this and the micro USB port can be bought right here. Use this teardown to help you with the task. Hope this helps, good luck
Was dit antwoord nuttig?
Score 1
where else can i get the Charging Port Dock Connector Flex Cable for this phone?
1 Opmerking:
@Rahim,Here and more here. The best would be if you did an online search to find something that will suit your needs and location.
door
Is the i9100 charging port compatible with the T989?
2 opmerkingen:
Looks like it is, The T989 is just the T-mobile version
door
They are not the same. Not even close.
door
Voeg je antwoord toe
mike zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 32,416
