Ga door naar hoofdinhoud
The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
197 Vragen Bekijk alle
Vraag afgerond
The temperature is about 90° and once it reaches 100°
sorry!
my friend give to me an old powermac g5 for big problem.
after mac os start, the temperature is about 90° and once it reaches 100° goes in protection.
i see no fluid loss, but i think the problem is with cooling.
any idea? thanks
this is solution? http://www.saunalahti.fi/~holindho/g5-qu...
really thanks
Is dit een goede vraag?
2 opmerkingen
Is that 90 degrees F or C
door
is celsius degrees :(
probably i have to change water pump and get new liquid! it is not easy but I groped with the link step.
if I succeed, I will proceed with the calibration fan with ASD Dual Boot 2.5.8
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Run your Apple Hardware Test (AHT) from the original system installation disk. Hold down the "D" key on start up with the disk installed and see if its the coolant or possibly one or more of the fans.
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
i will try, but all fans are going fast...
thanks for support
door
finally find asd but now the g5 won't start :(
his make fan check, and monitor don't show nothing :(
door
no moore idea?
really thanks
door
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 357
