Ga door naar hoofdinhoud
A type of digital audio player (DAP), MP3 players are electronic devices that can play MP3 digital audio files.
6 Vragen Bekijk alle
My MP3 Player is not getting detected.
Hi,
I am unable to switch-on my MP3 player and it is also not getting detected when i try connecting it to system. Please help on this.
Is dit een goede vraag?
Score 2
5 opmerkingen:
Information on this is difficult to find. Any make or model numbers on your device?
door
When i had one of these back in the day it powerd itself up when i connected it to the PC. Does yours power up ?
Did u forget and old battery in it and did battery acid leak out ?
door
Hi,
when I plug in my digital mp3 into computer USB port it will not detect on my PC but the digital was connected as charging.
door
Hi @ Jaynald Aranas
Was your mp3 player switched on?
If it was switched on, what is the make and model number of the mp3 player?
What is the make, model number and installed OS of the computer?
door
hi i have the same trouble but with "you have to format it before use"
door
Voeg een opmerking toe
3 Antwoorden
prrasuna, if it does not turn on and is not detected, I would start by replacing the battery.
Was dit antwoord nuttig?
It looks like the one I have. I had alot of trouble searching fo information about it as well. I got lucky 1 day and finally found what i was looking for. Try this address ( http://www.manuals365.com/swf/element/gc... ) Hope it helps.
I have the same problem
Voeg je antwoord toe
prrasuna zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 1,373
