2/3 screen gray bar top to bottom
Daughter's ipod touch just started with a 2/3 screen gray bar across from top to bottom that blocks everything from being seen. Is it history?
Is dit een goede vraag?
Jane T, from the way you describe it, most likely a failed LCD. Either way, you will have open up your daughters iPod. Use this guide and while you are at it, double check all cables and connectors. There is always a chance of a tore cable or a corroded connector. Hope this helps, good luck.
Was dit antwoord nuttig?
Thank you. I'll check into it... after all what have I got to lose! :)
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 302
