3 red lights flashing on my xbox 360
My xbox 360 has three flashing red lights and it will not show anything on my tv it says no signal what could be wrong with it please help me
Is dit een goede vraag?
Annuleer
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkelkim, you did not tell us which lights are red but I bet it is sections 1, 3, and 4 that are flashing red. This would be a "General Hardware Failure" Try this :"Check the secondary Error Code:
Try restarting the console.
If restarting the console does not resolve the behavior, follow these steps:
Turn the console off.
Unplug all the power and AV cables from the console.
Unplug the power cord from the wall socket.
Firmly reconnect all the cables.
Turn on the console.
If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
Also examine the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the RoL flash red." from here. If this did not resolve anything, it is time to either fix it yourself with these guides and parts, or have the motherboard professional reballed. Hope this helps, good luck.
Rep: 1
i fixed mine red ring of death no thanx to u
This problem occured to me suddenly today during a thunderstorm causing voltage to be incosistent.I tried restarting the console sometimes with no result. Afterwards i checked the power supply and its led was RED , i detached its plug from the socket and attached it again , the led became orange and once powering the console up , it became green and the xbox run as usual.
Afgelopen 24 Uren: 36
Afgelopen 7 Dagen: 158
Afgelopen 30 Dagen: 707
Altijd: 73,514
I have the 3red rings on mine and my xbox fan is running. so im guessing my power supply is ok. i just dont know what's the problem with it
door M Hapha
I fixed my red ring of death
door Red Ranger24k
Hey there! to make it easier for other people, How did you fix it?
door Aiden Baker
