Ga door naar hoofdinhoud
Released in 2010, the Flip Mino HD is a pocket-sized camcorder with 4 GB and one hour of shooting capacity.
25 Vragen Bekijk alle
Where can I find a replacement screen for Flip minoHD?
The screen on my MinoHD was damaged. The Flip Video support folks tell me my only option is to toss it. I'm unwilling to accept that without first trying to fix it. Where can I buy a replacement screen for the camera?
Thanks,
Bob
Is dit een goede vraag?
Score -1
1 Opmerking
Is it under warranty?
door
Voeg een opmerking toe
5 Antwoorden
Gekozen oplossing
These cameras are effectively priced to be disposable, parts are nearly impossible to find. What I would do is find a parts camera on a site like eBay with a good LCD and transplant that into your camera.
Cisco doesn't sell parts and replaces the entire camera, so it's likely they just recycle them once they get yours. The problem is the parts cost often exceeds the value of the camera and it doesn't make sense to repair them or stock parts.
Was dit antwoord nuttig?
Score 3
As Nick said, check eBay. You can probably find one that has other defects otherwise and take the screen from there. Once you have the extra Mino, use the teardown to remove the screen and install it on yours.
Score 1
I know the non hd version uses the same lcd as the iPod nano 2g but im not sure about the hd, you can just google the part number (located under the ribbon) and im sure you can find a replacement
hello i had a bad lcd in minohd 120 min , and replace it with a display from flip ultra standard U1120 , is the same part , i search for the part number and i couldn't find anything , right not i am going to get an lcd as Jakob DylanG sad for ipod nano and see if it work , thanks and i hope it help somebody else
1 Opmerking:
hey, yuberth
did the ipod nano 2g lcd screen work for the ultra hd flip camera?
door
finally i change it with the display from another flip a 60min not hd the use the same , but I check the replace for ipod nano and contact board part is shorter that the one for flip screen itself looks the same but I never try it.
Voeg je antwoord toe
Bob Flynn zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 6,263
