Ga door naar hoofdinhoud
Why won't the internet (wifi) work?
I installed a airport card into my machine, selected my wifi network, but when i tried to go to any website it says, "the specified server could not be found". What should i do?
The computer has internet explorer 5:2 and running Mac OSX 10.2
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
It could be any number of problems. OS 10.2 is obsolete and does not support modern wireless encryption, so it may not be working with the security settings you have in place on your router. As a test, you can disable wireless security on your router, and if it suddenly works, you know that's the problem. Even with Tiger 10.4 (the OS that you should get and install on your machine), due to the wireless-b card your machine uses, you cannot use WPA2 encryption, which is the standard on a lot of newer routers, so it's necessary to re-configure them to use WPA Personal instead. I don't recall what encryption 10.2 is compatible with, but it's probably WEP, which is not all that secure and should be avoided.
Internet Explorer is also obsolete and unsupported on the Mac at this point, and even if you get it working, it's going to be a sad browsing experience, with the vast majority of websites not coming across correctly, if at all. There may be an old version of Firefox you could get and install on 10.2, but really any effort you put forth should be spent getting 10.4 Tiger on your machine. I'd try the wireless security test I mentioned above first, but then definitely go get Tiger.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
got tiger and it works fast and PERFECT =D
door
Is there a way to use air airport extreme station as a bridge to get an old g4 to pickup WPA2?
Voeg je antwoord toe
Ted Mayer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 2,357
