I have a water damaged Retina MacBook Pro, what are my options?
I have a water damaged 15" rMBP, everything works fine and dandy except that it will not charge. Maybe it's the charger? The battery? The cable that connects the battery feeding power to the system? No idea. I can only use it if it's plugged in which is a HUGE bummer for me. I have Apple Care, but Apple obviously won't help me. I tried and they didn't, I don't think a different rep would make a difference . I know I messed up, but I've come to accept that fact at this point. I was wondering if there is anything I could try/fix/replace to get the charging working again? If there was water damage to the logic board wouldn't everything else stop to work as well? Theres gotta be something to try.. please help!
Is dit een goede vraag?
4 opmerkingen
just remove the battery and logic board from top case and clean it properly. then try it
door SIMRAN
Do you want to sell this macbook pro ?
door SIMRAN
Pull the logic board out, and clean it well, especially the battery connector (the plug on the logic board itself). I would recommend using a tiny bit of DeOxit D5. It will clean and increase the conductivity of the metal. You can get it at Guitar Center or online. Let it dry for a couple hours before turning it back on.
door Evan
You do have to be very careful with contact cleaners in general.
Ones with a lube really shouldn't be used on logic boards. It you must use it clean off the lube with a non-lube cleaner afterwards. Dust tends to cling onto the lube and it tends to migrate into & under the chips and other components causing them to fail. If you use them near the LCD you can damage it.
While the idea of something that neutralizes the oxides (corrosion) on a logic board would be ideal, I have not found one which does not effect the chips & SMD components negatively over time. Remember once you clean the board of the corrosion it won't continue to corrode. So the need for a preventative solution is not really needed.
door Dan
