Also known as the Incredible 2, the successor of the HTC Droid Incredible is identifiable by the model number S710E.
10 Vragen Bekijk alle
Why does my battery port works in just a specific way?
So whenever I try to connect micro usb, it only work when i hold it in a certain way. How can i fix it?
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
2 Antwoorden
Gekozen oplossing
Dev Patel, sounds like you need to replace the USB charge port. Here is a decent video for that procedure. You can either try and find a USB port that matches, at places like Mouser.com or Digikey.com, and try to solder it to the flex, or replace the assembly with a part like this. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 1
Turkey is right. This is a pretty easy repair for a charge port. No soldering is required. Definetely replace the whole assembly. It is faster and gives a more professional repair.
Voeg je antwoord toe
Dev Patel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 1
Altijd: 613
