Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Vragen Bekijk alle
Home button doesn`t work, how to solve?
My home button was working sometimes but for a while it is not working at all. I am using the virtual home button under the menu of accessibility.
Is there anyway to solve this problem ?
Thanks.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Before changing the home button try to use contact spray if this does not solve your problem i think you should change the home button.
Was dit antwoord nuttig?
Could be Home Button Flex. Could be Charging Port with Flex. Could be Logic Board and no fix. Like Loukas advised, start with Home Button Flex.
thanks...
Voeg je antwoord toe
Burak zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 459
