MBA won't detect hdd, what part to replace?
Hi, I've been trying to fix an old macbook air but am running into the flashing question mark folder on it. I've tested the harddrive on another computer and it works fine. I've also put in a osx install flash drive and on the "select the disk" screen, nothing shows up.
What part could be causing this? Is it the cable that attaches the hdd to the motherboard, or could it be the motherboard itself?
thanks~
Is dit een goede vraag?
4 opmerkingen
sorry but I'm having the same problem, did you get solution?
door Joel Luciano Lopes
Why guess is that the cable was bad.
door Scott Dingle
Joel - It's best to create your own Q as your details are likely different which maybe a different problem.
door Dan
Thanks for the reply, I fixed the problem, really was the cable, the cable was passed inside the protective rubber of the HDD, rubber and support of hdd pressured the flat cable and the connectors could have contact, the MBA found the piece. Thanks a lot.
