Ga door naar hoofdinhoud
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 Vragen Bekijk alle
Vraag afgerond
Uppgrade MacBook Pro Retina
Hi! I want to buy a Macbook Pro Retina 15". And expand it with a larger SSD and memory. It is much more cheaper than buy already installed? In the cheaper model's there is only 8gig ram is installed but I want 16gig.
Is it possible to uppgrade memory and the SSD in a safe way? Will work well? And, what will happen with the waranty?
Is it easy to get the custom special connection for the SSD?
Does the memory use standard connections?
I want 16gig because I will be editing films.
I want a way to save money as I can't afford buying the top model :)
Thanks for a very interesting website!
Dear Regards Daniel Femrell
Ps: sorry for my bad English Ds
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Daniel - First you don't state which model you are looking at (13" or 15") as there are some differences between them on where the SSD is located and possible future options.
Both models use soldered on memory (RAM) as such you can't expand it later.
Both models use a special removable SSD module. In the case of the 13" Apple created a large void which could hold the just announced 500M & 1G 5mm HD disk drives (not available yet). You can't do this yet, but I think Apple was planning for them.
You still can upgrade the SSD later, here's one choice, there are others: OWC SSD upgrades.
Upgrading the SSD is not very difficult and you could put the old unit into an external case to use as a backup. Apple will still honor their warranty as long as the device didn't cause the problem (a good reason to say with one of the major 3rd party vendors).
Was dit antwoord nuttig?
Score 1
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 3,853
