Howard Lowitt, hope everything else is okay after the hurricane. Anyhow, try this first. Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off. If that does not do it, try putting the machine into diagnostic mode.
DIAGNOSTIC TEST
The washer must be empty and the control must be in the OFF state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
■ Close the door.
■ Push CONTROL/ON (if present on this model).
■ Select the DRAIN/SPIN cycle.
■ Select NO SPIN by pressing the SPIN SPEED touch-pad.
■ Push PREWASH OPTION four times within five seconds. (If PREWASH OPTION is not present on this model, press EXTRA RINSE four times within five seconds.) C:00 will light up on the display.
If the Starting procedure fails, push the PAUSE/CANCEL touch-pad, then repeat the starting procedure.
Test Program Control
In order to advance to the next step of the test procedure, push PREWASH OPTION touch-pad two times. If PREWASH OPTION is not present on this model, press EXTRA RINSE two times.
If that does not work, or if if it won't enter diagnostic mode, then you may need to replace the main control board. You can get the service manual from here. You can also find plenty of information on here and here as well. Hope this helps, good luck. Stay safe....
12 opmerkingen
Thank you. It worked for me.
door P N Seshadri
Thank you! This worked perfectly!
door Kanay Coleman
I had the same problem due to an electrical outage here, I forget the fix, but it's in the manual, scary, but simple fix.
door Doug White
Hi i have the same problem and did not have any success in having any light or sound but the control lock light on. As soon I touch any thing else it will flash 4 times and back to steady that’s it. Any other suggestions? I unplugged it twice already!
door Val Ulric
I mistakenly tried to turn resolve this by hitting the control lock and when nothing happened I assumed there was a problem. If you press and hold control lock until it counts down 3,2,1 and then off. This turns it off.
door Marc Jacobson
7 commentaren meer tonen
