Ga door naar hoofdinhoud
The Kenmore Elite HE3 is a washing machine by Kenmore.
668 Vragen Bekijk alle
How do I remove the Control Locked light which prevents starting
After the power returned from the hurrican, the Control Locked light was on. Tried everything to remove or override but nothing worked. What can I do short of calling a repair man?
Is dit een goede vraag?
Score 25
12 opmerkingen
Thank you. It worked for me.
door
Thank you! This worked perfectly!
door
I had the same problem due to an electrical outage here, I forget the fix, but it's in the manual, scary, but simple fix.
door
Hi i have the same problem and did not have any success in having any light or sound but the control lock light on. As soon I touch any thing else it will flash 4 times and back to steady that’s it. Any other suggestions? I unplugged it twice already!
door
I mistakenly tried to turn resolve this by hitting the control lock and when nothing happened I assumed there was a problem. If you press and hold control lock until it counts down 3,2,1 and then off. This turns it off.
door
7 commentaren meer tonen
Voeg een opmerking toe
13 Antwoorden
Gekozen oplossing
Howard Lowitt, hope everything else is okay after the hurricane. Anyhow, try this first. Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off. If that does not do it, try putting the machine into diagnostic mode.
DIAGNOSTIC TEST
The washer must be empty and the control must be in the OFF state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
■ Close the door.
■ Push CONTROL/ON (if present on this model).
■ Select the DRAIN/SPIN cycle.
■ Select NO SPIN by pressing the SPIN SPEED touch-pad.
■ Push PREWASH OPTION four times within five seconds. (If PREWASH OPTION is not present on this model, press EXTRA RINSE four times within five seconds.) C:00 will light up on the display.
If the Starting procedure fails, push the PAUSE/CANCEL touch-pad, then repeat the starting procedure.
Test Program Control
In order to advance to the next step of the test procedure, push PREWASH OPTION touch-pad two times. If PREWASH OPTION is not present on this model, press EXTRA RINSE two times.
If that does not work, or if if it won't enter diagnostic mode, then you may need to replace the main control board. You can get the service manual from here. You can also find plenty of information on here and here as well. Hope this helps, good luck. Stay safe....
Was dit antwoord nuttig?
Score 27
29 opmerkingen:
I tried your sequence to reset my machine and it worked!!! Thank you so much.
door
AS soon as I hit the drain spin button the Control Locked button went off. THANKS!
door
Yes, this worked - thanks!
door
Holding the "End of Cycle Signal" worked for us on our 2008 Duet Whirlpool. Thanks so much!!! 7/9/17 - the Whitelys
door
OMG! IT WORKED! YOU ARE A GENIUS IN MY BOOK! I was about to call a repairman on a Sunday, can't believe I am not going to spenD that money I don't have! Glad to be a member of this valuable site!!! THANK YOU!
door
24 commentaren meer tonen
Mine was the "Drain/Spin" button and the "Start" button at the same time.
Score 6
3 opmerkingen:
I tried holding the control lock for 3 sec it blinked then stayed on and it won’t let me turn on any other buttons
door
Worked! Thanks for the help!
door
Worked for me. Thanks!
door
Press and hold the drain/spin cycle button for 4 seconds should do the trick
Score 3
4 opmerkingen:
Thank you. Been working on this for three days! I love you.
door
Thank you so much it worked drain spin.then end of cycle button. You are the best.
door
Holding End of Cycle Signal worked for me. Thanks Whitley’s
door
Washing machine remains lighted when not in use
door
Had mice enter the control panel and fray the wires. After making the repairs, the control lock light was on and no suggestions here would fix. Holding the spin speed button and end of cycle signal button for 4 seconds worked however!
Score 2
4 opmerkingen:
What you said worked . Thanks so much for the help . GOD bless you and your family
door
THANK YOU SO MUCH !!!
That suggestion worked for our Whirlpool Model GHW9250ML1 !!! Have been searching for a fix for our washer all day. Husband gave up and was trying to find an appliance repair shop to come out. Our washer is from about 1998 and we couldn’t find the owners manual. YOUR quick fix saved the day, and $$$$$. THANKS AGAIN. Jean W.
door
Thank you so much. After the hurricane mine wouldn’t go off. And by reading your comments it worked. Saved me some money.
door
Thanks! Totally worked for me after trying all the other options listed here. Mine is an old whirlpool duet, model GHW9300PW4. Hope this helps someone else.
door
On my front loader I had to press and hold the control lock button until it beeped then the LOC light popped off
Update (09/24/2016)
I held down the "control Lock" button on my front loader until it beeped. A few seconds then the LOC error popped off. It happens a lot when I accidentally lean or touch the front of the machine which happens with almost no intent. Plays the on/off tune then powers on or off. This is a design flaw if you ask me.
Score 1
4 opmerkingen:
Thank you, that worked for me, Lisa.
door
Thank you it worked for me too :) Tracey
door
Holding down on the Control Lock button until it beeped, cleared it for me! What a relief, thought I was going to have a service call. Saved me $$$.
door
Mine doesn't have a control lock button only a contol on and that didn't work holding it or the cancel button
door
I tried everything to get the control lock off on my whirlpool duet washer need help bad. I unplugged it for 15 minutes to reset it and still nothing.
Score 1
2 opmerkingen:
Push spin speed and then end of cycle. And mine started right up good luck.
door
Thank you it went off Let’s see how long it stays off Thank you very much
door
I had to push Add steam button and start. Automatically corrected it and was able to wash clothes and finish tidying up!
my GE machine needed me to hold both warm rinse an d auto soak (the 2 of which locked controls in the first place) for about 10 seconds...now working fine.
Not an answer. Control lock goes off intermittently and returns. It will go off after any button is pushed for three seconds except the end of cycle button.
2 opmerkingen:
Chris Werner. Is it a question? Something like "Why does the Control lock go off intermittently and returns?"
door
Sorry, I was following the questions and answers that preceded - The last one was, "Was this answer helpful? None of these worked so are not the answer for my situation. Unplugging for extended period worked for a bit but it beeped intermittently throughout. Now that doesn't work either. I have tried all of the button combinations. Can't get it into diagnostic mode.
Question: does it need a new control unit, perhaps?
door
The control board is locked.it starts up but i cant choose anything.actually buttons don't work.what should I do?need help
Thanks for the good ideas to bring it. I know a lot more. :) [url=http://balltoyou.com][size=1px]ดูบอล[/size][/url] :J
I have a whirlpool duet sport washer. When I power on the control panel looks fine. I choose a cycle press start. The door locks and stays locked. The dance/ pause button light comes on. After pressing the pause/ cancel button, it stays lit? Door still locked, the the “add a garment” light turns on. Then the changing the cycle doesn’t work. The time remains stays the same as the cycle chosen initially. At this point no buttons work. I did a diagnostic test and the only code that appears is f-24 (temperature sensor, but I replaced the sensor with a brand new one). Help please! And what does this error code have to do with the door?
THANK YOU!
None of this works and there is no control lock button just a light and control on button. None of this stuff worked! I cleaned the filter that was on the hose and now I’m having this problem of control lock!
Voeg je antwoord toe
Howard Lowitt zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 115
Afgelopen 30 dagen: 493
Altijd: 214,011
