Ga door naar hoofdinhoud
The Samsung Galaxy Note II is a smartphone noted for its combination of a large display and software optimized for an integral self-storing stylus.
209 Vragen Bekijk alle
Remove embedded sim card in Sprint's version of Samsung Galaxy Note II
Unfortunately, Sprint decided to lock and embed their international sim card in the device. Is there a way to open the case and take out the sim card so that when going overseas anyone can use local international plans instead of Sprint?
Is dit een goede vraag?
Score 7
5 opmerkingen
This question was migrated from http://meta.ifixit.com/Answers.
door
hello!!! i have a note3 which is cdma sprint can any one please help me to make my note get unlock pleaseeeeeeeeeeeee
door
Hey! I hope this has been resolved already, and if anyone is still struggling to figure out a solution to this, I'd recommend trying out http://www.unlockyoursim.com :) It worked for me. Hope this helps!
door
So there is no way to make it prepaid through sprint or maybe straight talks bring your own phone plan ?
door
I have a Samsung model no SPH A500 ? Does it have a sim card or not?
door
Voeg een opmerking toe
9 Antwoorden
Gekozen oplossing
READ: ALL Sprint phones from the CDMA era like the Note II were killed with the T-Mo merger! These will not work as phones now in the US, but for contextual reasons if someone buys one of these bad phones they know what they got: a brick.
CDMA phoned are locked to their respective carrier permanently due to how they work with no way to fully unlock them due to the SIM being embedded on the board. It can be programmed with the MSL, but the carriers hold the MSL hostage to stop you.
Even with the MSL and reprogramming done, the carriers are super particular about making sure thr ESN is theirs, and not a reprogrammed phone. I’m addition to the MSL, you need to do this every time you switch.
Yes, it's possible to reporgram one of these phones. No, you can't ever fully unlock it. In addition to that issue, Sprint is the absolute worst with unlocking phones, since they got a pass to SIM lock Verizon didn’t from the FCC. They also refuse to unlock phones because they got a pass to do it and refuse to give up control over the devices carrier lock as well. It technically is possible but they go out of their way to make it as hard as they can just be diss they can.
This is in contrast with a GSM phone, which use a SIM card. You can change the SIM cards, as that's how the communications are handled. The only thing the phone is essentially does is acts as a radio. As such, it's practical to unlock these phones. The reason these can be unlocked in most cases (old Nokias without a keypad code can be but it needs SW, but those are the exception not the rule) is due to the way they work, basically just a radio which speaks through a SIM card.
Was dit antwoord nuttig?
Score 4
8 opmerkingen:
So is it not possible to get inside of the plastic in the back to find the embedded sim card and maybe take out the solder?
door
I understand what you mean, but if you look around on Sprint forums and other sites, people like me want the ability to use foreign sim card. This isn't about unlocking GSM for the US carriers. CDMA might be old but it's fine for voice and text.
The Sprint software on the phone can easily be hacked to change settings for GSM, but the main issue is finding the SIM card slot so that it can be replaced when overseas. Sprint made a terrible decision to do this with all their "World phones".
door
Correct, but apparently (and I think this is a load of BS) they did this in response to unlocked phones being bought on contract, shipped overseas and then the contracts being cancelled just so foreigners can have the phones. Despite this stupid policy on their part, it'd be great to see ifixit or someone else take this phone apart to show us how to remove the embedded sim card. Anyone? Please? :)
door
Actually, they do this because too many people have discovered that prepaid is a lot cheaper. You get more for less with prepaid than you do with an account but without the insurance. People would get a phone under contract and then discover how high their bill was compared to their friends who were using prepaid sim cards.
door
Yes you can I did it I'm using a sprint phone as I speak or while I'm typing this my provider ultra mobile and its gsm uses a sim card its possible many things have loop holes if your smart you can figure it out almost everything Is possible
door
3 commentaren meer tonen
The Note II has both CDMA and GSM capabilities. It is a "global phone" as termed by CDMA providers such as Verizon and Sprint. Unfortunately Sprint decided to embed the SIM card unlike Verizon which has their SIM slot accessible. This means Sprint users are forced to pay Sprint's rates when travelling abroad instead of just popping in a pay-as-you-go SIM card from another country to save money on rates. Stupid Sprint.
Also, the Verizon Note II comes unlocked. My friend tested it by popping in a Tmobile SIM card and he was able to make phone calls using the Tmobile number on this Verizon Note II.
Here is a thread on XDA detailing the possibility of switching out some parts to convert the Sprint Note II to have an accessible SIM slot:
http://forum.xda-developers.com/showthre...
Score 3
not entirely true.
check it out.
YES CDMA phones can't be switched. Duh. But the Note II is capable of GSM too... the embedded sim is nothing more then a normal sim card.
check this thread at XDA. Solder in a dual SIM, load up the software and your good to go. Well... as long as you can get the battery cover back on.
Update
CDMA phones don't use SIM cards at all. Unless the are world capable (international) phones. In that case, it uses CDMA on the sprint network, and the GSM for when traveling abroad (unless your in the rare location of the world that serves CDMA). You're correct that it doesn't use any sort of physical chip accessible to the customer to connect to the network. It uses a serial number of each specific phone to permit access.
That's why on sprint and Verizon you have to contact them with the ESN or MEID to switch the phone service. Even then the ESN has to be registered with that specific network. Sprint to Sprint and Verizon to Verizon.
On t-mobile and at&t you can just flip flop your SIM.....
World capable phones on Sprint (or Verizon i guess) can do both flavors if you play your cards right. Its just the matter of what phone you have and what you plan on doing. If its a International capable phone, its pretty much just a matter of software. Either getting your cell phone carrier to unlock it or unlocking it yourself.
So for the instance of our Note II, Sprint was kind enough to not use a physical SIM card that could be removed and replaced with a new carriers sim card. No, the decided to embed the little guy making it nearly impossible to switch out. That way you CAN'T (easily) switch out the SIM to your carrier of choice. Sprint will say its in an effort to prevent international phone fraud. Which doesn't really make sense but that's beside the point.
I'll be getting my Note II next week and plan on doing a test run of soldering a dual SIM connector and putting in the SIM switching software. Its possible. Its been done before. If you do decide to do it, its not going to be for the faint of heart, it would take some physical meddling of the innards.
check this.....
Done with the Motorola Photon Q
Developing for the Note II
Sim switching (dual SIM)
http://www.magic-sim.com/
Score 2
CDMA phones in europe and asia are available with RUIM or removable user identity modules. Same as SIM cards but different software loaded.
There are phones available there with 2, 3, or 4, possibly even 5 card slots with 1 or 2 of them for CDMA.
Verizon and Sprint don't want that in north america. It's about control and mone, not preventing fraud or other such bs.
Score 1
1 Opmerking:
has anyone tried to use a CDMA with a RUIM card in the U.S. ?
door
True, CDMA phones do not work on SIM technology; however, all LTE caable CDMA phones have an embedded SIM with a unique hard-coded ICCID that the network uses for LTE authentication. If the hard-coded ICCID belonged to a phone that was reported lost or stolen, it gets blacklisted just like an ESN/IMEI would.
It is not an actual SIM card. It is a surface mounted chip, one of those small black rectangles on the board, with no visible soldering joints. Because of this, it requires hot air rework to be removed (hot-air pencil). A regular soldering iron won't cut it.
It is a litttle smaller than one square cm, and will say something like:
<letter and some numbers>
<first 10 digits of the ICCID>
<last 10 digits of the ICCID>
XX NEX
I literally, not 5 minutes ago, swapped one from one of my Sprint Galaxy s3's to another.
The donor is a 16gb with some water damage, and had an embedded SIM with a clean ICCID. The target is a fully functional 32gb board that I bought used, but the embedded SIM has a bad ICCID (so no LTE). Swapped the bad one with my original good one, and now I have working LTE on the 32gb.
Look into surface mount soldering/desoldering. Basic tools will set you back at least 60$.
Score 1
just to let everyone know the sprint sph l900 can use a GSM sim all you have to do is take the sd modual out and replace it with a Sim + Memory Card Reader Tray Slot Holder Flex For Samsung Galaxy Note 2 N7100 and select GSM under modile networks. I just need a way of getting reed of their damb apps.
Score 1
1 Opmerking:
What is a sad modual an how do you remove
door
Just to add, as far as the Unlocking of the device Sim/Network, if it pertains to an older model phone, I have found that you can contact Sprint through their online chat and the I got the unlock information in a matter of 10 mins. As well, through AT&T there is an online form to fill out, quoted 5-7 days, but received my email in only a few hours. As long as it's not the newest device, they will honor the unlock. Cheers
Score 1
Not all CDMA Carriers are this way, for example all Verizon smart phones come from the factory unlocked for use with all carriers(including iphones). You can unlock a sprint phone by obtaining a code from sprint but they don't like to give them out unless you're a good long time customer, however even unlocked most sprint phones still have very little usability with other carriers other than the iphones. An unlocked sprint iphone can be used on any carrier. I hope this helps.
I have a samsung note 2 SPH-L900 sprint how to use with a sim card. Other said i ll buy a simcard slot in note 2. Pls help me how's?
Voeg je antwoord toe
no way zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 28
Altijd: 143,449
