Ga door naar hoofdinhoud
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
154 Vragen Bekijk alle
The glass is gettin off, after replace, how I can paste it?
I´ve replaced the glass of my ipad 3rd generation, but a few days after that.. the glass start getting off near the home button zone...
What is the best way to paste the glass properly?? is it necessary to heat gun?
thanks and regards,
Marcos
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
1) You have to clean the display bezel from old adhesive or glass.
2) if you bezel is damaged buy a new one: iPad 2/3/4 Display Bezel
3) Use iPad 3rd Gen Adhesive Strips to paste the glass iPad 3/4 Adhesive Strips
iPad 2/3/4 Display Bezel Afbeelding
Product
$14.99
iPad 3/4 Adhesive Strips Afbeelding
Product
$6.99
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
ok thanks, I´ve have already bought a new Adhesive, and the bezel it´s okay i think is not necesary to buy a new one.
I clean de bezel.. but perhaps still having waste of the old glue. should I use some cleaner like alcohol or something?
and... when i use the new adhesive, Is is necesary to use heat gun?
Thanks for responding!
door
Please use only heat to clean the bezel and no heat to paste the glass.
door
ok thank you very mcuh.. when the adhesive arrives i will try this way..
thanks and regards,
Marcos
door
The iPad Retina Adhesive Stripes will help secure the iPad glass touch screen digitizer to the chassis.
However, to properly affix the screen's frame you will need the iPad Adhesive Strips for the Screen Frame which is the same for the iPad 3rd-Gen and the iPad 4th-Gen.
Pic:
Hope this helps,
Danny.
1 Opmerking:
I have the same problem. I have added new iFixIt strips, cleaned the bezel (not damaged), and tried the "red tape" approach. It sticks until the heat of the battery charge/discharge warms things up. Then the screen starts releasing starting along the edge between the home button and the corner where the ribbon attaches. I have tried clamping the screen with spring clamps. It sticks until it gets a little warm from use. What is the factory doing that we aren't??
door
Voeg je antwoord toe
markossampa90 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,878
