Repair guides and support for Kenmore washing machines.
1429 Vragen Bekijk alle
Can I replace parts on a Kenmore HE4T washer?
I would like to know if someone can replace the motor control unit and motor to a Kenmore HE4T washing machine. I would like to do it myself if possible. I would buy the parts myself.
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Score 1
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
2 Antwoorden
Gekozen oplossing
rm2sm, it is most certainly possible for you to replace it. The motor controller should be on the left side behind the lower access panel and the motor. Once you remove the panel you should see it. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
Your machine is actually a Whirlpool. Kenmore (Sears/KMart) doesn't actually make ANYthing. So you may want to start by finding which model of Whirlpool washer you have and get parts from them.
Score 1
Commentaar:
Your Kenmore HE4T is actually a Whirlpool Duet.
door
Voeg je antwoord toe
rm2sm zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 1
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 2
Altijd: 968
